Autopilot
- Merkinbrumsky
- Vessel Info: 1985 Carver Voyager
- Has thanked: 16 times
- Been thanked: 11 times
Re: Autopilot
- Aa704
- Vessel Info: 1992 carver voyager 28
Re: Autopilot
- Merkinbrumsky
Re: Autopilot
- Big Giant Head
Re: Autopilot
- Pura Vida
- Vessel Info: 93 Carver Mariner 330. 2X 350XL Crusaders
- Has thanked: 17 times
- Been thanked: 7 times
Re: Autopilot
The EV150 does NOT require rudder transducer, my system does not use it. Attached to the Garmin 94 through a databus, works very well.
You must know what helm you have, what type of hydraulic system, and ram size. See viewtopic.php?f=10&t=8015&p=63304#p63304 for additional info.
All SeaStar helms have the required check valves for an autopilot system (this is what i have). Some Helms would require an additional double piloted check valve to operate properly.
My system does not have a reservoir, i cannot advise specifically on this setup, but i know it is do-able.
My biggest PITA on installation was the hydraulic adapters from the pump to the steering lines (mostly self induced), and especially the data bus set-up...additional Garmin data bus cables are a ridiculous $50+. You will need to figure out and customize your data bus to your equipment.
All in:
$2200 (minus a $200 rebate at the time) for the EV15
~$200 hydraulic lines, fittings, fluid, helm servicing adapter...etc. (lots of extra parts...fittings & hyd hoses)
~$200 data bus connections/cables...etc.
On my Mariner, the pump and Flux valve (compass sensor) are all behind the helm, working in "the hole" sucked, but i never had to route anything through anywhere. Most other systems (best i can tell) would require the rudder transducer wired connection - again, EV system has connections for, but does not require rudder position.
Good luck! I am thrilled with the performance of the EV150 on the Great Lakes, best investment.
