2006 56 Voyager TV Lift Problem
Navy88
Vessel Info: 2006 Carver 560 Voyager
Twin Volvo D9 575hp
Postby Navy88 » June 17th, 2017, 10:07 pm
Hello - after a lightning strike at the marina my 2006 56 Voyager salon TV lift no longer works and is stuck in the "down" position (stowed). Has anyone had a similar problem or had to access this lift mechanism? I can see the TV from the side by removing the stairs to the bridge, and I can access the lift controller only by removing the couch cushion at the lower helm, but I cannot figure out how to access the lift motor/mechanism itself. It looks like it may require removing the entire range and hood, but before I attempt that I thought I'd ask some other owners. Any help is appreciated - thanks!
V One
Vessel Info: 2005 560 Voyager
Re: 2006 56 Voyager TV Lift Problem
Postby V One » July 11th, 2017, 5:31 pm
You might want to check with Bryan Voelz at Carver. He has been a wealth of technical information to me on our 56.
920-822-7310
Srm77
Vessel Info: 2004 560 Carver Voyager, Volvo V12 engines
Postby Srm77 » May 17th, 2019, 8:16 am
Hi! We are having the same problem with our TV lift.
Wondering if you were successful in fixing it?
The Morrison’s
Erie, Pa
Alaska 530 Voyager
Has thanked: 42 times
Been thanked: 33 times
Postby Alaska 530 Voyager » May 17th, 2019, 8:27 pm
Mine does that from time to time. I kill the shore power and the gen and it resets.
Has thanked: 431 times
Been thanked: 1586 times
Postby Viper » May 17th, 2019, 10:09 pm
The lift works off AC not DC?
Alaska 530 Voyager
Postby Alaska 530 Voyager » May 27th, 2019, 1:21 am
Sorry Viper, just realized you were asking me a question. My lift is aftermarket. It's 110 AC. When it malfunctions, it will reset and work again if I kill the AC power. I have to take the inverter offline to do this.
A Lee
Vessel Info: 2005 56' Voyger
Been thanked: 3 times
Postby A Lee » June 18th, 2019, 8:01 am
I would suggest checking the limit switches first. Also, remove the switch that activates up/down and bypass the switch by touching the wires, I had to replace the switch when I had similar issue.
Users browsing this forum: No registered users and 6 guests
