Gen Runs but Not creating power
- 650Guy
- Captain
- Been thanked: 35 times
So my 2003 carver 396 with Onan generator was launched. The marina launched it while i was away. When I came to the boat, the Generator was turned off at the generator itself (not the remote start switch at the power panel). I mention this as I have never turned off the generator there so am assuming the staff did this. After rectifying that issue I got the generator to run and it runs perfectly fine, but will NOT provide power at the panel.
it sure seems like there is a breaker popped or fuse blown that I am unaware of. things I have checked:
* at the generator, the field breaker is normal.
* at the generator, the 75 amp breaker is normal
* battery on/off switch is verified ON
* Power panel was triple checked and no voltage or amp pull no mater what I do.
Any thoughts on something I could have missed?
- Has thanked: 550 times
- Been thanked: 1151 times
Re: Gen Runs but Not creating power
Can you normally hear that auto transfer switch clicking after starting the gen or do you have a manual shore/gen switch?
- 650Guy
- Captain
I think I have switched just about everything I can think of on/off a couple of times, including the 75amp breaker on the unit itself. I have been cruising through the parts manual and found the voltage regulator so maybe that is the issue.
I will be headed back out to the boat on Thurs and think I'm going to test the Voltage Regulator. I have never done that before, so not FULLY sure where to start with THAT. Generators are not my friend.
- Has thanked: 257 times
- Been thanked: 1104 times
- Has thanked: 60 times
- Been thanked: 980 times
- 650Guy
- Captain
KM1125 - I'm not super familiar with a "reflash" or how to test the capacitors. Any chance you could elaborate?
- Georgeviking
- Vessel Info: 1995 390 cpmy
1978 32’ Uniflite sport sedan
1968 31’ ulrichsun
1968 31’ broad water
1977 19’ checkmate
1975 17’ west wind. - Location: Strong Island N,Y
- Has thanked: 4 times
- Been thanked: 3 times
And test it there ,, or pull cover off generator breakers and check for power right at the breaker ( might be the most straight forward ) this way you will know if power made or not, may have indications lights in there also, if no power the cap is next easy one down the line. And don’t have me calling you sparky
- 650Guy
- Captain
So what happened?
1) They told me the generator had to be producing voltage otherwise it would shut itself down. So that was good!
2) They had me remove the front cover on the generator and test the voltage on the breaker(LIke GeorgeViking talked about) I was showing voltage between 6-10 volts. This was just enough to keep the relay closed and the generator running as it clearly saw voltage!
3) I tested the voltage coming in/out of the regulator, and it too was showing 6-10 volts.
with this I was scratching my head and knew I would be making another call to Flight Systems.
So as I put the generator back together, I tried a hail Mary pass. I turned all my AC units off at the breakers, flipped Line 2 to GEN, and then, with the gen running, I increased the voltage with the voltage adjustment screw on the panel of the generator. about 1/4 of a turn, and it jumped from almost nothing to 120v! Tyler at Flight Systems told me to just run it as is and keep an eye on it. as these generators get old and don't have a lot of use, they sometimes will run into stuff like this. They STRONGLY recommend RUNNING YOUR GENERATOR WITH A LOAD as often as you can! He said its better to have a generator that is 5 years old with 5000 hours then 5 years old with 50.
Flight systems has a ton of parts and specializes in rebuilding old parts, but in my case if a voltage regulator was needed, it was $2000! Tyler told me that they could get me a multipurpose unit at a much lower cost that would work the same, just take some modifying to mount it.
so as Paul Harvey used to say (Yes i'm showing my age here) "and now you know the REST of the story"
- JimN
- Vessel Info: '89 Carver Santego 38
YMMV.
Good to see that it's working.
