Voyager 450 genny exhaust
- mjmason1
- Vessel Info: 1999 Carver Voyager 530
- Has thanked: 2 times
- Been thanked: 19 times
- jnick
- Vessel Info: 2000 Voyager 450
Twin Volvo 460 - Location: Long Beach
Re: Voyager 450 genny exhaust
- 2000450
- Vessel Info: 2000 carver 450
- 2000450
- Lyndon670
- Has thanked: 124 times
- Been thanked: 139 times
First off, the hulls are the same for the 53 Voyager, 57 Voyager and 506. You genny exhaust should exit on the port rear quarter of the hull. The AC lines exit under the swim platform. Typically the bridge AC (if equipped) exits on the starboard side, and the cabin AC is on the port side.
Also, your swim platform is hollow. It is designed to be part of your trim tab system. If you have water coming out of your rub rail, you have a leak in the lines running through the platform to the chrome vents under the platform. The cavity in the patform has the potential of holding 2-300 gallons of water - its huge. It will also have water if the caulking around the platform fails or needs replaced.
My spring project is to replace the caulking. In the interim, I cut a 4" waterproof access plate into the swim platform last summer and vacum out the water with my shop vac once a month or so. There is nothing exposed in the platform, so no water penetration to be concerned of.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- mjmason1
- Lyndon670
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Users browsing this forum: No registered users and 37 guests
