Rain water pooling in battery switch panel box
- jdb1540
- Vessel Info: 2000 Carver 350 Mariner
- Has thanked: 550 times
- Been thanked: 1151 times
Re: Rain water pooling in battery switch panel box
There are a few areas to look at, because this is a liner style boat water can run between the top and lower.
Along the top of the steps on the starboard coaming are some plastic covers , above those is the joint for the radar arch, also the side railing mount, and a hand rail mount if you have that.
Do you have things mounted to the small hard top behind the seat, also the edge joint on the hardtop leaks, on ours I drilled a hole on each side under the back corners to let water out.
The side window rubber seal can also get dried out, shrink and leak.
The starboard rear bridge seat area that has storage under....make sure the thru drains are not plugged, as it drains forward for the most part.
Well you can see there are quite a few areas to address.....good luck man
- jdb1540
- jdb1540
