Carver 400 MY engine RPM issue
- hausherrs
- Vessel Info: 1996 Carver 400
- Has thanked: 5 times
- Been thanked: 10 times
This past weekend I took the family out into the bay and the stbd engine wouldnt go over 2500 RPM when I had the port at 3000. I backed the port down to 2500 and the stbd would follow it down regardless of throttle. When I throttle up the stbd it would drop 200 rpm.
No smoke or strange noises. Temps and oil pressure were normal.
I have a set of fuel filters I need to put on. And im planning on sending off the injectors for cleaning.
Any ideas?
Thanks,
Steven
- Been thanked: 587 times
Re: Carver 400 MY engine RPM issue
- Has thanked: 431 times
- Been thanked: 1586 times
Complete assembly:
https://www.marinepartssource.com/newdetails.asp?pnumber=CRURA077013&mfg=crusader&mcat1=17&mcat2=0&mcat3=0&mfgcategory=Fuel+Filters&mfgno=RA077013%20%20%20%20&desc=110+Micron+Fuel+Filter
Filter:
https://www.marinepartssource.com/newdetails.asp?pnumber=CRUR077013&mfg=crusader&mcat1=17&mcat2=0&mcat3=0&mfgcategory=Fuel+Filters&mfgno=R077013%20%20%20%20%20&desc=Fuel+Filter+Screen
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- mjk1040
- Been thanked: 236 times
https://www.amazon.com/gp/aw/d/B002XKFM ... PDKIKX0DER
- hausherrs
Ill pull that filter apart this evening. I have a set of those pricy TB filters. They just need to be installed.
One thing worth mentioning is that engine RPM seems to get lower and lower every time I take it out. Junk in the filter would make sense.
Thanks,
Steven
mjk1040 wrote:Source of the post ...you think Crusader or Carver anticipated crap from the fuel tanks in these models?....
This was a Crusader thing. Can't remember the recommended service interval off hand but I check them whenever I preform fuel service on a Crusader that has them. I find if they have never been serviced, they can get so bad that I don't even bother cleaning them and replace instead. After that, if serviced regularly, a cleaning is all they need. Crusader recommends they be checked within several hours run time when the vessel is new as it's likely to trap debris from a new tank/vessel build. But I suspect that's rarely done from what I've seen, which is unfortunate as it's the first line of defense in the system if memory serves me correctly.
- hausherrs
