Carver 530 Pilothouse Cummins rebuild in engine room?
- glynnalan
- Vessel Info: 2000 Carver 530 Voyager Pilothouse
"Tina Marina" - Location: Henderson NV
- Has thanked: 5 times
- Been thanked: 3 times
I lost a starboard impeller which started a chain reaction of damage to the turbo, rocker valves and piston.
Before scoping the piston we replaced the turbo and impeller but heard a rattle in the valve cover. After removing we found a rocker lifter damage on the cylinder nearest the turbo. We removed the injector to scope the piston and found the damage attached in the photo. Looks like the valve seat did the damage from overheating.
My question is has anyone had experience in replacing pistons / bottom end without removing the engine from the boat? we are going to attempt to rebuild inside the engine room (it's really the only option). The marina we are at has no mechanical services or a way to get our boat out of the water at lake mead.
appreciate any advise!
Motor model: Cummins 6CTA 8.3 M2
Boat: Carver Voyager 530 Pilothouse
thanks,
Glynn
303-748-8989
- Has thanked: 550 times
- Been thanked: 1150 times
Re: Carver 530 Pilothouse Cummins rebuild in engine room?
https://boatdiesel.com/Forums/Index.cfm
- Has thanked: 60 times
- Been thanked: 976 times
I'd think the biggest challenge will be cleaning up the cylinder. Is it a sleeved engine?
- Sgodfrey
- Vessel Info: Carver 450 Voyager
- Has thanked: 1 time
- Been thanked: 7 times
- glynnalan
- glynnalan
- aussie530carver
- Vessel Info: 1999 Carver 530 pilothouse
- glynnalan
- Sgodfrey
https://www.sbmar.com/articles/propping ... el-engine/
- aussie530carver
I have had both of mine rebuilt here in Australia at a cost of $36000 per engine but i can only manage max RPMs at 2270... would anyone know what may cause the engines not to make max RPMs...
Users browsing this forum: TruckerTim and 5 guests
