Fuel transfer pump
Preferred
Vessel Info: 455 Carver 1998
Has thanked: 6 times
Been thanked: 2 times
Fuel transfer pump
Post by Preferred »
My fuel transfer pump is leaking when turn on to transfer from one tank to another.
1998 Carver 4808 . Can this be repaired or replaced?..
Preferred
Re: Fuel transfer pump
Post by Preferred »
455 carver diesel engine
Been thanked: 1794 times
Ya it's pretty common for those pumps to leak. Yes you can replace the pump, they're readily available online or your local marine supply store. I'm sure you can source a replacement seal too if you want to go that route but considering you're dealing with fuel, it's best to replace the pump.
Preferred
Post by Preferred »
Thank you, I have never had to deal with this issue.
