Battery Question
ataylor233
Has thanked: 52 times
Battery Question
Postby ataylor233 » December 28th, 2018, 9:53 am
i have a Carver 3207 I have a 2 Batteries , bank 1 and 2 on the switch ... I would like to add a Second Battery to one bank and run it in parallel so 1 will be 1 battery and switch 2 will be 2 12 volts run in parallel. running ruffly 200 amp hour my question is does anyone see any issues with this when it comes to charging with the alternators i also have a 3 bank charger i only use 2 leads ? ? ? ? ?
Has thanked: 3 times
Been thanked: 215 times
Re: Battery Question
Postby km1125 » December 28th, 2018, 10:28 am
You have to read the charger manual or consult the manufacturer. On some you would only use two leads, but on others you'd hook two of the leads to the same battery and one of the leads on the other battery or the charger won't function correctly (or you lose out on the total capacity of the charger).
Otherwise, don't see any big issues with what you're trying to do. You're just doubling the capacity on one side. If you were going REALLY big, say 4 batteries on that side, then there might be a concern about the alternator size vs the battery bank size. With just two I wound't be concerned.
ataylor233
Postby ataylor233 » December 28th, 2018, 12:52 pm
km1125 wrote:Source of the post You have to read the charger manual or consult the manufacturer. On some you would only use two leads, but on others you'd hook two of the leads to the same battery and one of the leads on the other battery or the charger won't function correctly (or you lose out on the total capacity of the charger).
Thank you for your input i will check out the charger info
Vessel Info: 2001 350 Mariner
Has thanked: 271 times
Been thanked: 448 times
Postby bud37 » December 28th, 2018, 1:43 pm
ataylor233 wrote:Source of the post i have a Carver 3207 I have a 2 Batteries , bank 1 and 2 on the switch ... I would like to add a Second Battery to one bank and run it in parallel so 1 will be 1 battery and switch 2 will be 2 12 volts run in parallel. running ruffly 200 amp hour my question is does anyone see any issues with this when it comes to charging with the alternators i also have a 3 bank charger i only use 2 leads ? ? ? ? ?
Sounds good, just take the power off the other end of the bank from the ground......should be just fine.
"There is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.”
― Kenneth Grahame, The Wind in the Willows
Safe travels with light winds and calm seas.....
Cool Time ...out.
Vessel Info: 1989 Carver 3807
Has thanked: 133 times
Been thanked: 591 times
Postby Viper » December 28th, 2018, 9:31 pm
Technically, while it's done all the time, you should know that simply adding a new battery to an existing bank that contains batteries already a few years old may reduce the life of the new battery. It's always best to keep all the batteries in the bank the same age and spec. Eventually the old battery in that bank will have a reduced capacity to fully charge. However, until the battery is fully charged to spec, the charger will continue to try and reach the level of charge it's programmed to achieve. While this is helpful to try and get the old battery's voltage up as much as possible, this continuous output will overcharge the new battery. If you're going to go this route, smart charger or not, make sure you have good cables, good connectors, tight connections, AND check battery fluids often, especially the new battery. What type and spec are the two existing batteries, and how old are they?
Users browsing this forum: No registered users and 4 guests
