wi-fish vs sonar phone
amanphoto
Has thanked: 2 times
Been thanked: 8 times
Re: wi-fish vs sonar phone
Postby amanphoto » January 18th, 2018, 7:13 am
Thank you. That's good to know.
amanphoto
Postby amanphoto » January 18th, 2018, 7:14 am
Thank you. That's good to know. Sorry posted twice. Computer hick-up.
Has thanked: 169 times
Been thanked: 194 times
Postby bud37 » January 18th, 2018, 8:36 am
amanphoto wrote:Source of the post Is there a difference in performance of a transducer that is through hull mounted or transom mounted? Is one transducer better then the other?
I have installed transducers to shoot thru the hull and they have worked fine, one was on a high resolution paper graph used for salmon fishing on Lake Ontario, it worked great........the trick is the install prep. set up the system with the transducer in a zip lock bag full of water then try different locations to find the best spot....then to fit it sand the selected spot smooth, build a dam around it and pour two part in there, then push ducer in trying not to have any air spaces, bubbles etc. Remember that transducer is just a sensor inside a block of resin, much like what you will create.
Better is the hole in the hull, but this if done right will work fine, unless you want to see minnows at a 1000' when you are doing 30 knots.
amanphoto
Postby amanphoto » January 18th, 2018, 11:47 am
I'm also a scuba diver. Can i pick up stuff on the bottom to dive on with the sonar?
Vessel Info: 1989 Carver 3807
Has thanked: 65 times
Been thanked: 367 times
Postby Viper » January 18th, 2018, 1:27 pm
You can with a CHIRP unit. It's hi res/def. Big difference over traditional sonar.
http://www.raymarine.com/view/index.cfm?id=11201
Scroll down to the Raymarine Dragonfly. The picture will give you an idea of the difference between the two technologies:
https://www.sportfishingmag.com/fishing-boats/making-sense-higher-and-lower-cost-chirp-sounders#page-6
Users browsing this forum: No registered users and 1 guest
