Inverters Shorepower and switches
- Iguana
- Vessel Info: 32' Carver Mariner
- Has thanked: 547 times
- Been thanked: 1142 times
Re: Inverters Shorepower and switches
Are you saying you have an inverter charger set up ??
- mjk1040
- Been thanked: 236 times
- Has thanked: 431 times
- Been thanked: 1586 times
Iguana wrote:Source of the post...Does the switches for 1-2-none-both matter when I am connected to shore power and not on the boat?.....
Yes it matters. I turn mine to "off" when away from the boat. Regardless of the position you leave the switch in, the charger will charge your batteries as it's either hooked up directly to the batteries or to the source side of the selector switch unless a previous owner made some changes. DON'T leave the switch on "Both" as this will combine banks and render your charger's bank isolation useless. That is a good way to shorten battery life, and if one battery is bad, you'll toast all of them because you've combined them all in the "Both" position.
