Impulse QT-204 Depth Sounder trouble shooting
- Capn Crunch
- Vessel Info: 1995 Carver Santego 310
Crusader 350XL injected, Hurth Inboard - Location: On the Mighty Columbia River in the Pacific Northwest
- Has thanked: 87 times
- Been thanked: 7 times
Any one have any suggestions?
- Has thanked: 432 times
- Been thanked: 1588 times
Re: Impulse QT-204 Depth Sounder trouble shooting
Does this happen at every depth? I assume you checked the ducer face to ensure it is free of marine growth?
- Capn Crunch
Viper wrote:Source of the post Does this happen at every depth? I assume you checked the ducer face to ensure it is free of marine growth?
First, Thanks Viper for the reply!! It does happen at every depth... from the time I turn the unit on... when I first turn it on it shows only "0.0" and then after a short period of time it starts flashing the 0.0. The transducer is mounted to the internal side of the hull... I don't think it protrudes thru-hull, although I never checked while it was trailered... being a new to us boat and having no previous experience w/cabin cruiser (bowrider doesn't even have a fishfinder, let alone sounder) I didn't think to check that aspect of boat - total noob here lol. The sounder worked when we purchased it and had just fine, until last week. That's when this started.
I buy into your explanation of replacement of both ends of system... it does however bring up other questions from the noob in me. Was considering adding a lower end chartplotter of some sort so I could cruise down river to Portland Ore from my Marina (about 220 miles as crow flies)... so mounting a new transducer - worried about poking a hole in the transom for the transducer first... second, stringing wire to bridge seems a bit problematic as wiring appears to be between ?hulls? not sure if that's the right terminology -
At any rate... just wondering how big a job this'll turn into?
Thanks again,
Mark
If you're thinking of upgrading, you can go with a ducer that shoots thru the hull so no holes needed though that wouldn't be my first choice, you can go with a ducer that mounts in a hole at the bottom of the hull, or if you have sterndrives, you can opt for a transom mount. The transom mount only requires a few small holes for a mounting bracket and a small hole above the water line where you would run the cable from the ducer to the inside of the boat. Then it's just a matter of finding a way to run the cable to the bridge. Following your engine harness and shift/throttle cables will lead you in the right direction.
- Mikep2389
Users browsing this forum: No registered users and 6 guests
