New Nav
- tomtomterrific
- Vessel Info: 1986 carver riviera 28
- Has thanked: 14 times
New Nav
I'm installing new Radar and MFD, replacing the old speedo and depth sounder.
Q - Would you remove the old through hulls?
How big of a DIY is it? I've done fiberglass work before but nothing as critical as a hull repair.
Cheers,
Cap't Tom
- Has thanked: 59 times
- Been thanked: 969 times
Re: New Nav
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 87 times
Re: New Nav
Good luck!
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- Tireless
- Has thanked: 183 times
- Been thanked: 185 times
Re: New Nav
- Has thanked: 432 times
- Been thanked: 1588 times
Re: New Nav
I don't recall what the '86 Riviera had for a hull...cored, solid glass? This would help my decision on whether I would remove the old ducers. If it's a cored hull, I would definitely remove the old ducers. Cored or not, if there are any signs they have been leaking, remove them.
- Sadey
- Vessel Info: Former owner of a 2003 Carver 356 with 8.1 Mercs
Agradecida
Current owner 1989 60’ Hatteras MY with 8v92 Detroit’s
Benedetto - Location: Racine Wisconsin/Ft. Lauderdale
- Has thanked: 4 times
- Been thanked: 29 times
Re: New Nav
Dave & Trina
- tomtomterrific
Re: New Nav
The old speedo and depth sounder units are mid 80's vintage and the old radar was Raytheon (pre RayMarine) probably also mid 80's vintage - no sign of leaks.
The new sounder is a transom mount. No new holes or reusing the old hole. Sounds like the consensus would be tidy up the old wiring and leave the old units in place!
Much appreciated!
- Has thanked: 314 times
- Been thanked: 583 times
Re: New Nav
Re: New Nav
tomschauer wrote:Source of the post Hey Tom, a transom mount transducer on an inboard boat is pretty useless unless you are barely moving. It will see the bubbles and such from the propwash and give you crazy readings. The transducer always needs to be forward of the props.
+1
- tomtomterrific
Re: New Nav
