396 Stereo Lovers
- 650Guy
- Captain
- Been thanked: 35 times
396 Stereo Lovers
what I would really love to do is remove both, and install a single unit that I could hear and use anywhere. To complicate things more I would REALLY REALLY love to tie in the TV so it could support the surround sound.
Has anyone tackled such a project? Maybe just upgraded the radio? I'm really not looking to putting a Dance Floor in my 396, just looking to get some idea's from what you all have done.
Would I be TOTALLY crazy to try and install a home surround sound system in? I mean if its in the main salon, its as comfortable as my family room of my house...
- Tireless
- Has thanked: 183 times
- Been thanked: 185 times
Re: 396 Stereo Lovers
I also have the Clarion Stereo on the dash in the fly bridge with a 1000 watt amp that pushes sound into the bridge with a sub, aft deck and the cockpit. I can play sound in the fly, aft deck and the cockpit or cancel the sound in these area’s using the fade. The speakers are JL Audio and they are very nice.
I have considered having one system, but I like to be able to separate the sound from inside the salon and outside. This is so the Admiral can do her thing and I can listen to what I want.
If I was going to upgrade I would just get a newer Clarion on the dash for bluetooth capability and better FM reception. I currently use a Bluetooth device hooked up through the Aux.
Greg
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 87 times
https://www.parts-express.com
Good luck!
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- 650Guy
- Captain
I do have a gen, and 99.9% of the time that I'm underway, I run it. the Denon AVR-S710W system I'm thinking of using has zone control, streaming ability and Spotify built right in. an APP that uses the WIFI system to control the unit, so AGAIN, if I have AC power my router is on, and can control it from anywhere on the boat. its a pretty sweet box! but no AC... its just dead weight on the boat! LOL
So plan B.
What if I leave the existing equipment installed, add the home system, simply splice into the speaker lines and in the event I do not have gen running, I could still use the standard system....
OR....
I could just be like a normal person and get a new radio that works on DC....
- SplashyLady
- Captain
650Guy wrote:Source of the post Oh man... that just dawned on me... DUH!!!! Underway the home system will not work... man, sometimes I miss the most obvious of things!
Don't discount the idea of the inverter - less than $100 for a 1000W inverter and you can run the system any time off the 12 VDC. You could put a small 12 V cube battery inline nearby as a reservoir (similar to using a capacitor, but less hassle) to stabilize the 12 VDC stereo power to the inverter. The Denon AVR-S710W is a 75W x 7 system with a maximum 400 watt input load. I doubt if you would ever run that system wide open for very long! Nominal load would likely be less than 100 watts.
KRIËGER 1100 Watt 12V Power Inverter Dual 110V AC Outlets, Installation Kit Included, Automotive Back Up Power Supply For Blenders, Vacuums, Power Tools MET Approved According to UL - $85 from Amazon.
Connecting speakers to two different sources often causes problems; amplifiers are not designed for back-feed and impedance could be a problem.
Lake Norman, NC
- Has thanked: 257 times
- Been thanked: 1101 times
I chose their blackbox unit as the main can be hidden anywhere, just a small remote that controls everything. Lots of options. https://www.fusionentertainment.com/marine
