chuck1869 wrote:Source of the post Thank you buster53 for the replies. One head is a Jabsco. Not for sure on the other. I'll look for the pump this weekend.
Any updates yet?
KyleR wrote:Source of the postIf your fresh water pump doesn’t stop running, you’ve either got an empty tank, the pump is faulty or you have a plumbing leak.
Also, some freshwater pumps, like our Shurflo Aqua King 2, have a pressure switch AND a bypass valve built into the pump, both of which are adjustable via a very small allen wrench. We had an issue with ours running for no reason and I ended up tweaking those setpoints until it operated correctly. There are videos on YouTube showing how to make the adjustment.
Might not be your problem, but definitely something good to be aware of!
Kyle, my buddy has an 01 396. He's the guy that got me into all of this. Been 7 years since then
