Fresh water pump
- Low Flyer
- Vessel Info: 1998 Carver 355 MY
Mercruiser Bluewater 454's - Location: Allatoona Marina Resort, Lake Allatoona, GA
- Has thanked: 2 times
- Been thanked: 7 times
Fresh water pump
Filter is clean, water tank is full, pulsates at all outlets.
Any ideas?
1998 355 Aft Cabin
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 464 times
Re: Fresh water pump
- Has thanked: 431 times
- Been thanked: 1586 times
- Low Flyer
Does anyone else have an accumulator tank on their fresh water system?
The boat wiring is actually a larger gauge than the pump wiring. All hose fittings are the same size as previous pump fittings.
I'm thinking (bare with me) that the pump is new with the same PSI output so it is cycling because it is reaching it's maximum output pressure without any bleed off. I will check my theory tomorrow by opening several faucets at the same time to see if it pulsates. If it doesn't pulsate then I would think that because of multiple openings in the system, it doesn't reach the automatic PSI cutoff to stop and start the pump.
Am I thinking about this in the proper sense or missing something?
1998 355 Aft Cabin
- mjk1040
- Been thanked: 236 times
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 60 times
SeaDragon
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
If you put in a higher GPM unit, the original feed lines could be restrictive. If this is the case just crack the faucet with little flow and see if still pulsating. In other words you are pressure balancing if smooth with just a slight flow then feed restriction may be the problem. Final idea is the internal check valves in the pump are faulty. Just ideas.
