Location of Water Shut-off
- Sailor Jerry
- Vessel Info: 1996 Carver 355
- Has thanked: 2 times
- Been thanked: 7 times
- Contact:
- Has thanked: 313 times
- Been thanked: 581 times
Re: Location of Water Shut-off
Tom
- Sailor Jerry
- Contact:
Thanks, Jerry
- Has thanked: 431 times
- Been thanked: 1586 times
The shore water inlet may also freeze so you may want to cap the line to it but you should blow through it also so that any water in the valve/regulator doesn't split it too.
Do you have an ice maker or sink in the cockpit that will be exposed to freezing temps too that you need to be worried about also?
If I were in the same conditions, I would plumb in shut-off valves in an accessible space in the boat with a means to drain those lines like a T and drain valve. This would make it easy to prep for winter without having to undo lines every year.
- mjk1040
- Been thanked: 236 times
- Sailor Jerry
- Contact:
- mjk1040
- Been thanked: 586 times
- nightsky
- Vessel Info: '94 Carver 390 cpmy
- Has thanked: 6 times
- Been thanked: 16 times
