cpoint wrote:Source of the post I looked online and cant find one exactly like it. Can I use a PVC T connector?
That pump should be under that waterline, right? If so, I'd do some digging before I'd use PVC. That's a general "no-no" - to use PVC below the waterline.
I haven't done enough digging to ever find out if this is just a myth or if there is actual basis to it, so I would check around first.
