Hot water tank pressure regulator spraying hot steamy water
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Any help would be appreciated. Boat is new to me, still learning.
Dan
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 396 times
Re: Hot water tank pressure regulator spraying hot steamy water
If hot steamy was coming out, I would bet your thermostat let the temp get up over 212f - very dangerous.
- Has thanked: 313 times
- Been thanked: 581 times
The relief valve works opens on high temp and / or high pressure, so if the stat doesn't turn off the heat it will open.
- mjk1040
- Been thanked: 236 times
- Has thanked: 547 times
- Been thanked: 1142 times
- mjk1040
- Has thanked: 431 times
- Been thanked: 1586 times
The only amount of pressure that should be in the hot water tank when it's cold, is your fresh water system or dockside water pressures.
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 462 times
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
