350 Mariner Air Conditioner Cooling issue
Bryon857
Vessel Info: 2002 carver 350 mariner
Has thanked: 2 times
Been thanked: 13 times
Postby Bryon857 » June 5th, 2018, 1:21 pm
I have a 2002 350 Mariner, I has a single ac 16000 btu unit under the fly bridge dash, above front bedroom. My question is, is this setup large enough to cool the whole boat? Mine does not seem to be able to keep up on a 80 plus degree day. Does anyone else have this problem or is my system going bad? I am considering a second 6000 btu unit, like Carver installed as an option. Just curious if anyone is cooling there 350 to satisfaction with a single 16000 btu?
Has thanked: 547 times
Been thanked: 1142 times
Re: 350 Mariner Air Conditioner Cooling issue
Postby bud37 » June 5th, 2018, 4:27 pm
Our 01 will take care of that just fine ( read meat locker )........check your ductwork up under the dash for rips/tears ( animals pick at that )....check your intake screens in the ceiling.....do you have good water flow ?...where are you located, water temp ? That is the easy stuff.....good luck man.
The above is strictly my opinion always based on years of doing...remember to support local business , it pays back.
Has thanked: 313 times
Been thanked: 581 times
Postby tomschauer » June 5th, 2018, 11:38 pm
Always check the air filter, if there are any, and the evaporator coil. If the coil is plugged with dust and dirt, your unit will have very little capacity.
I.E, you will be hot.
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 4 times
Postby Agriman » June 6th, 2018, 9:45 am
Our 1998 with the 16,000 BTU cools and heats great for the whole boat. I agree with cleaning the coils and ceiling air intake ducts. My only complaint is the compressor is a bit noisy when kicking on.
Bryon857
Postby Bryon857 » June 7th, 2018, 8:57 pm
Going to check coil tomorrow, I am sure it has never been cleaned. Thanks to everyone for advice.
Vessel Info: 2022 Stingray 182 SC
Been thanked: 462 times
Postby RGrew176 » June 8th, 2018, 4:37 am
It's amazing just how much better the unit will perform once the coils are cleaned. If the unit is in good working order a good coil cleaning can make a difference.
Bryon857
Postby Bryon857 » June 10th, 2018, 8:22 pm
Clean the coils this weekend, much needed. I think will work better, this weekend in Northern Ohio never got over 75 no real test.
[image][/image]
Bryon857
Postby Bryon857 » June 10th, 2018, 8:24 pm
This is before and after.
Postby bud37 » June 10th, 2018, 9:06 pm
The last two look like shots from the mars rover.... :lol:
Postby tomschauer » June 10th, 2018, 9:48 pm
Bet it works just a little bit better now?
