Black Water Holding Tank Level Indicator
- Mikwallace
- Vessel Info: 1998 Carver 405 AC 7.4 Horizon engines
- Has thanked: 109 times
- Been thanked: 20 times
The Holding Tank indicators do not indicate waste level in either holding tank. Is there a button to push to activate the sensor or does it indicate constantly? Only one time have I seen one of the indicators work and it showed empty (of which I'd just emptied the holding tank, so that was expected). I'm not sure if it was just a coincidence or not?? Here's a picture of my indicator. It's a VACU-flush system.
Thanks!
1979 Caravelle 18’
- Cooler
- Has thanked: 66 times
- Been thanked: 371 times
Re: Black Water Holding Tank Level Indicator
- Been thanked: 587 times
- Has thanked: 314 times
- Been thanked: 583 times
If you are sure the power is on at the 12vdc panel, get the boat pumped out. You should see green lights.
While at the pump out dock, run water into the toilets. The green light should go out after one or two flushes. No light will then be lit. Keep flushing.
The yellow light will light when you hit halfway. It will stay lit until you hit full. Then it will go out and the red light will light.
- Mikwallace
1979 Caravelle 18’
