AC water pump/ strainer and valve location ?
- Vessel Info: 1988 Carver 2827 Voyager
- dtcom
- Vessel Info: 1993 Mariner 330
- Has thanked: 4 times
- Been thanked: 3 times
Re: AC water pump/ strainer and valve location ?
REPOSE wrote:Source of the post Just put my new to me Carver 2827 Voyager in the slip yesterday , having trouble finding the thru hull connection and pump. There is no water flow through the unit and there for is not cooling. Thank you in advance for your help.
I don't know if this helps, but I have a Mariner 330. The thru hull is just outside the head, starboard side. There are 2 hatches outside the head to remove.
The filter on mine is a glass canister on the port side. Every time I have put the boat in, the filter needs to be cleaned.
Do you hear the pump running?
- Has thanked: 550 times
- Been thanked: 1145 times
Welcome to the forum.....where is your AC unit located on that boat ?
