generator switch over
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 5 times
Postby Agriman » May 28th, 2017, 9:36 am
I had some work done on my generator and on the weekend the generator started and ran great, but did not provide any power. Is there a switch to change from shore power? This is on our Mariner 350.
Re: generator switch over
Postby bud37 » May 28th, 2017, 10:07 am
There is a breaker ( maybe white double switch) on the side of the black box at the back top of the generator, check that first to see if it is engaged...guy maybe shut it off while working on it...... :beergood:
Agriman
Postby Agriman » May 28th, 2017, 12:43 pm
Thank you very much, I will check that out next time at the marina. I believe once turned on it automatically switches when plugged in to shore power.
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Postby feeez » May 28th, 2017, 11:01 pm
Agriman wrote:Source of the post Thank you very much, I will check that out next time at the marina. I believe once turned on it automatically switches when plugged in to shore power.
Alway ask the stupid question!!!! just in case. Did you turn on the shore power breaker(s) on the AC panel after the the generator was started? Sometimes they will trip during the genny startup.
Former 2001 350 Mariner owner
Agriman
Postby Agriman » May 29th, 2017, 1:55 pm
Yes the breakers were on. I'm pretty sure Bud 37 has the answer.
Agriman
Postby Agriman » June 4th, 2017, 1:30 pm
Thank you to Bud37. The switch is as you say and solved my problem. All is working great.
Return to “Electrical”
