Princess Oven Element Not Working on 3 Burner Electric Stove
Topic author - Scurvy Dog
- Vessel Info: 1987 Carver Aft Cabin
- Has thanked: 3 times
- Has thanked: 431 times
- Been thanked: 1586 times
Re: Princess Oven Element Not Working on 3 Burner Electric Stove
If there is no voltage at the element, start tracing the circuit back from there. If I recall, you'll have an oven selector switch as well as the thermostat. Check for voltage on both sides of the switch and the t-stat. With the t-stat turned on, you should have voltage though it. If you don't but have voltage up to it, the problem is the t-stat. Check all connections to make sure they are clean, corrosion free and tight.
If the broiler works, that indicates the broiler side of the t-stat is working. You can try swaping the broiler wire at the t-stat with the lower element wire. This should light up the lower element. If it does, the bake side of the t-stat has failed.
Careful here, you're dealing with 120 volts. You can use a meter or a voltage detector pen (everyone should have one on board). If you're handy with a meter, you can do a continuity check of the switch and t-stat in the "on" position.
