Carver 356 battery question
- Has thanked: 549 times
- Been thanked: 1145 times
Re: Carver 356 battery question
- Dweber01
- Vessel Info: 2000 406 aft cabin
- Has thanked: 1 time
Are all of the batteries in Carver group 31 as you mentioned?
Dweber01 wrote:Source of the post I’m also having battery issues on our new 2000 406. I had to kick in the generator to get the engines enough power to start and that was after driving it for 30 minutes.
Probably....but one thing before you go further, go down there and check the water in the batteries and clean all your connections and engine grounds...never know what you get left with.
Seems like the batteries are the first thing to replace when you buy a boat.....
- Been thanked: 587 times
i dont have group 31's in my 405 and i use golf cart batteries for my house bank.
you may want to check your battery selector switch under your stairs. if you are considering buying new batteries you may want to consider what type of boating you do and upgrading your house bank to a larger capacity at the same time
- Bentone23
- Vessel Info: 1996 Carver 355 Aft Cabin
454 xls EFI - Location: Central California
- Has thanked: 39 times
- Been thanked: 5 times
- Contact:
In order to find out which is battery one and battery two, disconnect positive cable from a battery and check each post on switch to see which one lost voltage.. do this with the switch off.
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
- Has thanked: 313 times
- Been thanked: 583 times
Users browsing this forum: Google [Bot] and 17 guests
