Brisson Vapor Alarming
- MCADRG
- Vessel Info: 1991 3608 Aft Cabin
Checked battery water levels all good.
Is sensor being finicky or do we have a problem?
Mike
- Has thanked: 550 times
- Been thanked: 1145 times
Re: Brisson Vapor Alarming
At this point you should assume you have a problem until you can make darn sure there is no fuel leak. So with all sensors they have a life span and do go bad, especially if the power is bad.
You say no fuel detection, how did you realize this? The human nose surprisingly can smell gasoline vapour/fumes at extremely low PPM, less than 1 PPM......remember gas fumes are more dense than air so will migrate downwards .
Be very careful here until the cause is found.
- Has thanked: 257 times
- Been thanked: 1099 times
- MCADRG
- MCADRG
Had mechanic onboard conducting battery load test (all good) and alarmed again. Found the sensor box itself was very hot, may have got increased voltage during a loss of shore neutral/reverse polarity alarm. Issue started at the same time. Ordering new sensor. Fingers crossed. Want a reliable alarm system.
- Has thanked: 59 times
- Been thanked: 970 times
I have found that some of the degrading sound insulation foam will also set off these detectors.
- MCADRG
Mike.
Yes, you do just pull out the sensor. It's a small grey round plastic 'plug' about 3/4" tall. The pins below look like an old vacuum tube.
