2000 Carver 356 Battery Issues
- Mbishop412
- Vessel Info: 2000 Carver 356
2000 Carver 356...
I replaced the batteries and charger with the identical units that came with the boat when purchased. The batteries have lost about 3 weeks now and will not start the boat. The charger was reading 14.2v on the readout, but is now reading 11.4. When attempting to start the boat, it reads 8.2. I can’t seem to pinpoint an exact issue because the charger is putting out 11volts it reads to the battery, and the batteries reads 11v each. Any idea why this sudden issue would be happening? The boat ran fine for years and was replaced identical to how it was, parts and all, but keeps dying?
- mjk1040
- Been thanked: 236 times
Re: 2000 Carver 356 Battery Issues
- Has thanked: 550 times
- Been thanked: 1145 times
The charger manual may have a troubleshooting section to help with power on/off issues.
- Been thanked: 587 times
- Has thanked: 59 times
- Been thanked: 970 times
- Has thanked: 314 times
- Been thanked: 583 times
If the charger does bring the batteries to 14+ volts and they can not start the engines when they are at 14+ volts most likely one of these problems.
1. The battery voltage drops to under 12 when you turn the ignition switch, motors don't crank or crank very slowly, but batteries return to 12v or above when not trying to crank. Most likely bad or loose connections at the batteries, battery switch or starters. (starters unlikely if both engine act the same)
2. same as above but battery voltage stays below 12v. Get new batteries, they are toast.
