Trumpet horns stopped working today
Helmsman
Has thanked: 71 times
Been thanked: 42 times
Re: Trumpet horns stopped working today
Postby Helmsman » October 10th, 2020, 10:36 pm
You mentioned fog. Mine went bad after I washed the boat one day. I had read that spraying a little WD40 would cause the horn to blow. It did. The horn failed the next time it rained. I replaced the horn and it works fine now. They are evidently more sensitive to water as they age.
Cliffm wrote:Source of the post So.... Plot thickens! Pulled under dash panel to access backside of horn mount wiring, looked good, so I removed dash panel to access horn rocker switch which turned out to be a relay switch. so I tried it and horn blew?
So, the $100 question. Is my "old" Marcinco AFI trumpet horns being temperamental/going bad... or is the horn "relay" rocker switch going bad when used "allott"?
Any EE's having insight to my dilemma?
Has thanked: 547 times
Been thanked: 1143 times
Postby bud37 » October 11th, 2020, 8:04 am
One thing is for sure, it is satisfying taking care of your hooters......... :-D
The above is strictly my opinion always based on years of doing...remember to support local business , it pays back.
Cliffm
Vessel Info: 2006 Carver 36 MY
"the Condo"
VP 8.1Gi-F
Has thanked: 260 times
Been thanked: 19 times
Postby Cliffm » October 11th, 2020, 9:18 pm
Nharrison5 wrote:Source of the post You mentioned fog. Mine went bad after I washed the boat one day. I had read that spraying a little WD40 would cause the horn to blow. It did. The horn failed the next time it rained. I replaced the horn and it works fine now. They are evidently more sensitive to water as they age.
Thanks, thinking that after finding our helm stereo speakers having severely deteriorated cones, and replacing them this weekend.
Cliffm
"the Condo"
VP 8.1Gi-F
Postby Cliffm » August 4th, 2021, 4:31 pm
They died!
went to WestMarine, bought the Marinko 12V 123db pair, swapped out, sounds great!
appear to be the same make as previous OEM installed units, hoping they last as long.
Return to “Electrical”
