Kohler 10eozd Generator Under Voltage Code
- Rocketman
- Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
- Been thanked: 17 times
If I keep trying to crank, it will eventually (after maybe 5 or so times) run and operate fine.
Seems to be a bad (corroded) connection or something.
Any suggestions on where to look or what to look for would be appreciated.
The manual is not much help on this code other than call for service.
- Has thanked: 550 times
- Been thanked: 1145 times
Re: Kohler 10eozd Generator Under Voltage Code
It may simply be the battery is giving up......but checking before deciding is wise in this case.
- Rocketman
It is sensing an under voltage on the A/C output and shutting down after 10 seconds.
I don't think it is the battery since it cranks just fine. I will verify though.
Will check the grounding strap as well.
- Has thanked: 314 times
- Been thanked: 583 times
- Rocketman
Where would it be located and any idea of a part number?
- Has thanked: 59 times
- Been thanked: 970 times
- Rocketman
Will see.
