Bulbs for Salon Lights
- Vessel Info: I presently own a 2001 450 Pilothouse. I have owned a total of 6 Carver.
The first was a 1984 Mariner 28. The others where aftcabins, 325,356,3807 and 4207. - Location: Charlotte NC
- Has thanked: 3 times
Thanks,
Steve
- Has thanked: 314 times
- Been thanked: 585 times
Re: Bulbs for Salon Lights
https://www.superbrightleds.com/moreinf ... G8%20Bulbs
Check to be sure you get the proper ones. I thought g6, but may be G4 or G8. Its been awhile!
- Phrancus
- Has thanked: 16 times
- Been thanked: 123 times
- Contact:
Earlier LED's were hard white light with little spread. Looks like a factory hall rather than a cosy cabin.
COB leds are generally more powerful and can give (depends on form design) more evenly spread light. And in warmer (lower temperature numbers) versions.
2000-3000 is whiter than the classic bulbs but not yet very white. 4000 and higher is very white up to white/blueish higher up.
It's a matter of taste and purpose where you prefer to have and where
I found some small LED bars in yellow and in red. These fit simply in a cabinet or storage area above the door on the inside. Makes finding things a lot easier. The red ones I use for night-light in the cabin and on the fly as background (floor) lighting, saving toes and knees while walking around yet keeping it possible to see in the darkness
- Been thanked: 589 times
Ive also bought from Superbrightleds and also Amazon will have a variety.
- Has thanked: 432 times
- Been thanked: 1594 times
Decide on the temperature you want. I like a warm white for ceiling and courtesy lights in living spaces but prefer bright white in the heads and closets. At today's prices, it's a good idea to purchase one of each contender and check their intensity. It's not uncommon for folks to order all their bulbs only to find they're not bright enough. If you have dimmers, they may have to be replaced with LED compatible units and the LEDs themselves must be labeled "dimmable". When installing, keep in mind that most are polarity sensitive. Unlike regular incandescent bulbs which don't care where the negative or positive sides are, LEDs typically depend on proper polarity to work. Most do however have reverse polarity protection so you don't blow them if inserted in reverse, they just won't work when in the wrong way. For the ceiling, pick a bulb that directs all of its light in a downward direction when installed. Also consider purchasing several more than you actually need as these will come in handy should one or more fail over time. This way the replacement will emit the same light as the others in the same space. Buying a replacement later will likely result in a noticeably different light from that fixture if it's part of a grouping.
- Has thanked: 550 times
- Been thanked: 1150 times
The other point to deal with will be the old light fixtures themselves. They can look fine till you try to get the old bulbs out, then the trim rings etc disintegrate/crack/break up as you work on them.Something to consider would be to replace the entire fixtures if you find yours in that shape.....I advise to check that first before ordering.
There are some very nice upgrades that fit the original holes......good luck with your up grade....
- buster53
- Has thanked: 8 times
- Been thanked: 254 times
As mentioned, be careful about the color tempurature. I prefer the warm whites in the high 2000 to low 3000 degree range. As you go up towards 4000, they become cool white which is way too bluish for my tastes.
- vineyardgray
- Captain
- Has thanked: 125 times
- Been thanked: 32 times
- Contact:
https://www.marineoutfitters.ca/index.cfm?category=10002|10000|11557&product=67765334&code=894638001610
1988 Carver
3867 Santego
PCYC
- vineyardgray
- Captain
- Contact:
https://www.doctorled.com/store/marine-LED-Light/Dome-Light/12V-Dome-Light-SMD-LED-Kit
1988 Carver
3867 Santego
PCYC
- Has thanked: 257 times
- Been thanked: 1100 times
