Page 8 of 11
Re: Carver 3207 Revised
Posted: November 23rd, 2014, 8:10 pm
by Mkemper
Started on this years winter projects.
First being new benzles for the windows. Shaped the polyiso for a positive mold. Priming sand and such then I will make a negative mold. The neg mold will be just oversized to allow for the fiberglass layup. If it test fits I will mold a copy and looking to have it vacuum metalized in a brushed stainles
Posted: November 23rd, 2014, 10:57 pm
by Lyndon670
Wow, that's some impressive fiberglass work. I love seeing someone work their own ideas up into reality.
Posted: February 21st, 2015, 11:14 pm
by Abear
Hello, I own a 86 Carver 3207 as well and am in the process of remodeling it. I really like the new instrument panel you installed on the flybridge of yours. If you don't mind, I'm very interested in how you made the components to make it look like it just came off the show room. Thanks, I'm looking for a project to start the Spring with to get ready for the season.
Posted: February 25th, 2015, 6:55 pm
by Mkemper
Abear wrote:Hello, I own a 86 Carver 3207 as well and am in the process of remodeling it. I really like the new instrument panel you installed on the flybridge of yours. If you don't mind, I'm very interested in how you made the components to make it look like it just came off the show room. Thanks, I'm looking for a project to start the Spring with to get ready for the season.
The carbon fiber I purchased a pre made sheet and used the existing panels as templates. The lables are from blue sea systems.
Below is a link to a post I made on the progress
http://www.lakestclair.net/index.php?/t ... pper-helm/
Posted: March 12th, 2015, 11:09 am
by Mkemper
Well spring is sprung and a new chapter begins
Biggest project this year will be adding a bow thruster to compliment the stren thruster. Going with a max power CT80
Cut the acess hole and tested the location
Marked up it location
Key parameters
185mm below the water line
Bottom mark is the bottom top lenght min
Adding a dedicated battery with 140amp combiner
If anyone is interested I can update the progress
Re: Carver 3207 Revised - 2015 projects & bow thruster
Posted: March 12th, 2015, 11:11 pm
by feeez
Pleeeeaase keep posting... this is amazing work!!
Posted: March 15th, 2015, 5:05 pm
by Mkemper
Drilled the small hole for the rod to pass through to mark to cutout. Probably the single most important thing you need to dead on.
Used a level on the drill as a guid.
Past the rod through to mark the other side. Checked for plumb and level
Marked the hole. Found that a series of taps or dots with the pen worked best
Hole all marked out
Posted: March 15th, 2015, 5:16 pm
by Mkemper
What a odd looking hole. In person it looks like a egg tilled!
So the check it I set up the tunnel
Took a picture down the tunnel. Happy to see the outline conform to the shape (red line)
Inside it looks like I will need to till the motor forward to decrease it height. I can notce the floor at the dotted lines. This will also be a good spot to support the motor
I was going to mount everything in the truster compartment that I will be in closing by making a fiberglass top. In rethinking I have a nice compartment that can hold the battery, fuses shutoff and such. This will be better in that acess is great and it's adjactent to the thruster
Posted: March 15th, 2015, 5:31 pm
by Mkemper
Used a laser on the square with level to check everything out
The tunnel optom depth is 185mm or 7-1/4". At the middle of my scum line it's right on. You cannot be under 5" or your performance will suffer
So this is how it checked out. Bottom of tunnel lenght is 9-1/4". I need at least 8" or risk the propeller blades sticking out. So i am good there. When done it will be a little more because I will add a eye brow to direct the water away from the tunnel. (Explain later) thruster ends up right on center were I cut the acess hole and will fit within the area with a cap. When done you will never know its there.
So it's time once the weather break to DRILL!!!!!!
Posted: March 21st, 2015, 5:24 pm
by Mkemper
So it begins
Drillin
Tunnel fit!!!!! Exactly were I wanted it
The hole. Video to follow
