Custom Underwater Lights.
- Has thanked: 254 times
- Been thanked: 1095 times
Re: Custom Underwater Lights.
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 397 times
- Has thanked: 313 times
- Been thanked: 581 times
- Has thanked: 57 times
- Been thanked: 968 times
A voltage regulator is probably a good idea. Even if the lights could tolerate the higher voltage, that also means more heat. More heat leads to a lot of other bad things happening.
- Has thanked: 431 times
- Been thanked: 1586 times
Ya it's inevitable. Even expensive units have the same problem. There was a thread a few years ago about aluminum underwater lights to which I suggested it wasn't a good idea for that reason but the OP was convinced they'd be fine. I know the boat and know that the lights on there now aren't the ones mentioned in the thread that he first installed. I suspect the corrosion got out of hand so he replaced them with something else. Don't get me wrong, there are aluminum alloys that do pretty good but you can't get away from aluminum being more active than the metals of inboard running gear. If you're going with aluminum, you better have some magnesium close by. If you know the composition of the aluminum, you may also be able to get away with aluminum anodes. Having said that, it's just safer to stay away from aluminum underwater lights IMO, I haven't seen one yet that doesn't eventually corrode to a point where it needs replacing.Midnightsun wrote:Source of the post.... Corrosion of the aluminum due to them acting as anodes....
Users browsing this forum: Carvrcapn and 25 guests
