List Your Practical Boating Accessories/Add Ons
- Has thanked: 257 times
- Been thanked: 1098 times
Please add any practical item that makes your life easier on board and a description of why if required.
Here is a very small and compact inverter. I used this to power my replacement TV in the master suite. As you know, 12v TVs are very limited and the quality sucks for the lack of a better word. I chose a standard 120v TV and used the inverter to power it. Simply cut and spliced the existing 12v source to the inverter and voila. Your existing dedicated 12v TV breaker still works as it should and will cut power to the TV as intended.
This unit is really tiny and has been in use for 2 seasons now without issue. The inverter presently is powering a 120v 24" Vizio led TV with plenty of reserve power left. It is rated at 150 watts so do not expect to install an 80" TV and run it with this unit. Check the power draw of the TV you intend on using and see if this little guy will suffice.
https://www.amazon.ca/gp/product/B01H2U9DE4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Re: List Your Practical Boating Accessories/Add Ons
I know, a clock is taboo on a boat but for me it is a necessity. I love projection clocks however they do require 120v so not practical on board. This guy connects via standard USB so it is always working and keeping time while projecting even away from shore power. Bonus is it has a USB plug in the rear so you can plug your phone to charge if you so please.
https://www.amazon.ca/gp/product/B07MDW457N/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
- Rocketman
- Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
- Been thanked: 17 times
Wireless remote control for 12v power lift pole that I inserted inside my salon table to power remote control lift and drop for making into a bed. Works great and I don't have to struggle with lifting the table by hand.
Solar panels on the hard top so I don't have to run the generator as much (20 amp max output total).
Misters connected to the raw water system and installed at bow pad and aft pad area. Use raw water remote to turn on and off.
2000 watt continuous/4000 surge true sign wave inverter (instead of the small noisy inverters) to run TVs, and all A/C 120v power on the boat. Wired into the main power panel on the Generator switch with a relay to turn off if gen set is cranked.
Also added relays to automatically switch off the battery chargers and hot water heater so those are not trying to run on the inverter. Basically inverter on - no chargers or hot water heater. Generator on - inverter off and all chargers and hot water back on. Done automatically with relays.
Added USB Fast Charging Ports all over the boat so I don't have to have full chargers everywhere. Cables are cheap to keep around.
- Been thanked: 587 times
- vineyardgray
- Captain
- Has thanked: 125 times
- Been thanked: 32 times
- Contact:
Super for extending the boat season in spring and fall when Air Conditioning is not needed but the condensation kicks into overdrive.
I'm going to sound like that old Remmington Electric shaver commercial, but I actually became a dealer in Canada because of how great the thing works.
1988 Carver
3867 Santego
PCYC
