2001 396 aft Cabin bildge pumps location?
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 40 times
- Been thanked: 22 times
I am not able to locate the aft bildge pump or the forward bildge pump.
The forward bildge is not under any of the access panels in the forward state room.
There is no access panel on the galley floor. I imagine its in the engine room behind the generator but I have yet to find it.
Regarding the aft bildge pump. I pulled up the carpet in the aft state room and removed all the access panels and no bildge pump. I did find the shower sump pump.
Could it be that Carver would hide the aft bildge pump under the shower sump? If so, you would have to remove all the drain hoses from the shower sump and the tub just to check the if the bilge pump functions. Would Carver actually do that or did the previous owner change things? I am the 3rd owner.
My marina neighbor has the same boat but a 2003. The forward bildge pump is under an access plate on the galley floor and the rear bildge pump is easily accessable under an access cover in the aft state room.
When I had the boat surveyed the surveyor noted the lack of easy access to to pumps an "area of concern and needs to be addressed".
Any comments are greatly appreciated.
Users browsing this forum: No registered users and 107 guests
