Water in the fuel tank
- Greenhornchris
- Vessel Info: 1989 carver 3207
- Has thanked: 2 times
- Has thanked: 60 times
- Been thanked: 979 times
Re: Water in the fuel tank
It would be a job to try and siphon the water from the bottom of the tank, but I think that model had the fill lines going straight down to the tank, so it might be possible. You'd probably have to siphon out a lot of gas with it to make sure you got most of the water.
You might want to go the professional route though. There are guys that "polish" fuel that would be able to remove the fuel that's in there and run it though some water-separating filters and maybe get most of it out. Make sure you carry some spare fuel filters on the boat for a while though and get good at changing them at inopportune times!
- ataylor233
- Been thanked: 6 times
- Cooler
- Has thanked: 66 times
- Been thanked: 374 times
You are not the first person that made this mistake. er
- Has thanked: 550 times
- Been thanked: 1151 times
Cooler wrote:Source of the post The water will sit on top of the gasoline
No the other way.....km and ataylor are correct...
- buster53
- Has thanked: 8 times
- Been thanked: 256 times
- Greenhornchris
- Cooler
- buster53
Greenhornchris wrote:Source of the post Guys I just want to thank you for all the information, my dad told me something similar that it will settle at the bottom. So the tank was completely full and yes the boat has 2 tanks so the hose was only in there maybe 30 to 45 seconds before it started rushing out the valve below on the hull and I realized what I did I'm guessing it's not more then a couple of gallons at the most. I think I'm going to take the suggestions buy 5 fuel filters and pump out several gallons from the bottom. I'm going to look for someone who might be able to "polish the fuel" as suggested and im spray painting the cap RED ! as the chrome is corroded and I can't read the labels although it's burned in my brain now. I'll keep you guys posted thank you so much this forum is awesome!
If you’re going to pay a guy to polish, as I suggested, just let him do the whole job. Getting water out is part of the polishing process.
- mjk1040
- Been thanked: 237 times
