Repair or Replace 1988 230-Mercruiser Engines
- jhrobins
- Vessel Info: 1986 Carver 28 Voyager Model 2827 Twin 230 hp MerCruiser moored in Bellingham Harbor, WA
Jim
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 397 times
Re: Repair or Replace 1988 230-Mercruiser Engines
Were they running ok at the end of last year?
1600 is allot of hours but if they were running fine and now not, that would not indicate a need for rebuild; probably something simple like anti siphon valves stuck, gas gone bad, etc.
- Has thanked: 431 times
- Been thanked: 1586 times
While 1600 hours is a lot for a gasser, hours don't really concern me as much as how they were maintained and run for those hours. If they were properly maintained with regularly scheduled oil changes using a good quality oil, tuned properly, and didn't have the heck run out of them, then they may be worth saving. Only a maintenance history will tell you that though, or an oil analysis, or tear down. I suspect they are fresh water cooled (engine coolant in block) as I suspect you're in salt water but if they are raw water cooled in salt water then I would go with a different set of rebuilds. Either way, if the exhaust manifolds are raw water cooled and haven't been replaced in over 5-7 years, they should be replaced with new ones.
Same deal with the transmissions and V-Drives. The condition of the oil is pretty telling for what's going on inside. Hopefully the oil hasn't been changed recently so you get a good picture of their condition by inspecting the oil. It should be clear and not smell burnt or have any solids in it. Also look for shaft creeping in neutral. While that's not too uncommon in older units with many hours, and is not too critical unless it's really bad, it is a sign that clutches in the tranny need servicing. Look for seal leaks in both units.
As Fred mentioned, your symptoms can be caused by several things and only some diagnosis will reveal what's causing the problem. Before you start throwing money at them though, do a compression test to see if their current condition is worth it. If you get good readings, get them running and do a vacuum test then decide how you want to proceed but remember that 1600 hours is pushing it if they haven't been maintained properly.
- Has thanked: 547 times
- Been thanked: 1143 times
- Has thanked: 313 times
- Been thanked: 581 times
Years ago I had a marina winterize my engines and they used so much fogging oil or just plain oil, my motors wouldnt start in the spring. I removed the plugs, cranked a few times and saw an oily mist come out of the cylinders. I then replaced all the spark plugs with new and they fired right up.
