New member
Horatio
Vessel Info: 2003 Carver 396, 8.1 Crusaders
New member
Postby Horatio » September 12th, 2021, 9:44 pm
Hello all, purchased a Carver 396 with 8.1 Crusader engines. So far, replaced control head (starboard engine idle only). Replaced relay board, Kohler generator, turned over when fuse installed. Soaked generator heat exchanger in Barnacle Buster and installed anode. Replaced plugs, soaked cylinders in mystery oil, squealed like a banshee when started, wrong impeller installed. Generator purrs like a kitten now. Tackling salon air conditioner tripping breaker now. Looking for Carver recommended blocking or cradle build instructions.
Vessel Info: 1981 Carver 3007 Aft Cabin
Has thanked: 54 times
Been thanked: 408 times
Re: New member
Postby RGrew176 » September 13th, 2021, 2:26 am
Welcome Aboard. Hang in there. Someone will be able to answer your questions. Lots of knowledgeable people here.
Has thanked: 5 times
Been thanked: 375 times
Re: New member
Postby g36 » September 13th, 2021, 10:59 am
Welcome aboard
Vessel Info: 1987 3697 Carver Mariner
1969 15' Glaspar / 1969 Johnson Electrmatic 85
1964 Barron Flat bottom drag boat
A couple of dinghies
Has thanked: 43 times
Been thanked: 331 times
Re: New member
Postby waybomb » September 13th, 2021, 6:41 pm
Welcome aboard.
Just about everybody by me uses blocks under the keel, spaced about every ten feet, and then 4-6 stands to stabilize the boat.
1964 Barron Flatbottom with BBC Chevy
1988 Cougar Kevlar 46' with triple blown 572s
http://s4.beta.photobucket.com/user/waybomb/library/
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 242 times
Been thanked: 110 times
Re: New member
Postby pepmyster » September 13th, 2021, 6:58 pm
Welcome!!!!!!!!!!
Has thanked: 311 times
Been thanked: 1162 times
Re: New member
Postby Viper » September 13th, 2021, 7:58 pm
Welcome aboard.
Users browsing this forum: buster53 and 17 guests
