Howdy from Kemah, Texas
- wsp2
- Vessel Info: 1995 Carver 440
- Has thanked: 4 times
1995 Carver 440
"Tempest"
Kemah, Texas, USA
1996 Boston Whaler Rage 15 - Location: Saint Joseph,Mi
- Has thanked: 50 times
- Been thanked: 398 times
Re: Howdy from Kemah, Texas
- Cooler
- Has thanked: 66 times
- Been thanked: 371 times
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 464 times
- Been thanked: 587 times
- Cooler
- Has thanked: 432 times
- Been thanked: 1588 times
- pepmyster
8.1 Volvo Penta
- Has thanked: 441 times
- Been thanked: 190 times
- wsp2
Cooler wrote:Source of the post Carver's 1995 production year featured a lot of coremat construction. The hull below the waterline +6" is solid fiberglass. Above that, up to the rub rail, is coremat. Instead of balsa core, coremat is more of a plastic panel that can not absorb water. Keeps the hull stronger over the long run. Not 100% sure your 440 was built that way, but highly likely. If your surveyor mentioned anything about moisture content being very low along the hull, that would tell you it is coremat. er
Thanks. Moisture readings were good except in one place - the rear port panel near the window. Looks like the window seals are leaking and getting behind the wall. It's one of the things we're investigating. There were also a number of blisters below the water line which will need to be dealt with.
1995 Carver 440
"Tempest"
Kemah, Texas, USA
