Spring launch almost here
- TJK
- Vessel Info: 1987 santego
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 464 times
Re: Spring launch almost here
- Has thanked: 431 times
- Been thanked: 1586 times
TJK wrote:Source of the post Its getting close to launch.... Replacing gimble bearings and u joints, bellows, shift cables and water pumps...... The previous owner had her for 10 years and did no maintenance what so ever......
For future reference, the Fall is the best time to replace gear lube, pull drives, and check u-joints, etc. If there's any water in the gear case, you don't want it there in the winter as this will corrode components and run the risk of splitting the case when it freezes. Same applies to the u-joints. If the bellows sprung a leak, you want to minimize the length of time the input shaft and u-joints are in contact with water. The longer they are, the more expensive the repair.
At the very least, the gear oil should be checked every Fall by pulling the plug so you get a small sample of oil and can see if water comes out. If there's water in there, it should come out first. If water has been there for a while, you'll have creamy oil. Black burnt oil is an indication there's something wrong internally or it simply hasn't been replaced in a while. IMO, the drive should also be removed every Fall, check for water in the bellows, grease the u-joints if applicable, check the gimbal bearing, grease the spines. AND, don't forget to replace the anodes.
Not servicing sterndrives for 10 years is a big no no, and what you think you're saving by not doing anything every year will cost you way more in the long run.
Good luck, I hope you don't run into any problems, and keep us posted on how it goes.
- TJK
There are loads of things to check on these drives. Now's the time to do that while you have things apart in case they are close to failing and end up forcing you to go through the whole process again.
PS: This job is a pain to begin with and even harder without the proper tools that make it a heck of a lot easier. some you can get aftermarket, some you can't but can probably make do. There are also aspects of this work that require things to be done in a very specific way or you'll cause other problems. Something seemingly simple like replacing a shift cable entails a specific routing and final setup or you'll never shift properly. You may want to search the net for a service manual (they're out there) and follow it closely.
- TJK
