Run Dry Impellers
- Has thanked: 257 times
- Been thanked: 1099 times
Re: Run Dry Impellers
Even if you were to double or triple the water flow from the pump it will not affect running temperature. The thermostat opens and closes to keep it at its set temperature and has nothing to do with flow. All excess non essential cooling water is simply bypassed.
Not sure why you are seeing different temps. Could be the new impellers are producing less flow, water is colder than a witch's tit and even with the thermostat fully open it cannot achieve rated temp is my best bet.
- Cooler
- Has thanked: 66 times
- Been thanked: 372 times
- Has thanked: 59 times
- Been thanked: 971 times
- Cooler
