1994 350 Aft Cabin
- dfirkins
- Vessel Info: 1994 Carver 350 Aft Cabin
- Has thanked: 1 time
- Contact:
1994 350 Aft Cabin
- Has thanked: 59 times
- Been thanked: 970 times
Re: 1994 350 Aft Cabin
My guess is you'd have at least 4' above the water at the bow, but considering the bow would still be a foot below the water (at least), you'd probably need a 6' ladder or so to make it.
- Been thanked: 587 times
- Has thanked: 314 times
- Been thanked: 583 times
If you are moving from a boat with an outboard or outdrives that you could lift out of the water while beaching the boat, you will want to consider changing your approach. You do not want your props and struts to be hitting bottom. They are really expensive to repair or replace. Much more so than an outdrive prop.
Consider anchoring out in at least 4' of water and use a dink or kayak to hit the beach.
Have fun!
- Has thanked: 550 times
- Been thanked: 1145 times
Good luck with your new boat.
Well, two things. One area we'd go into was virtually all sand, but there was the occasional rock. Dinging a prop on one of those wouldn't have been fun. I actually did ding one in an area close to that, but didn't plan on getting that shallow. I was in about 6' of water and dropped the hook, as the boat pivoted around in the wind, the aft end went a little shallower and there must have been a rock sticking up, because my prop hit something. Had to pull that and get it fixed.
The other area is almost ALL sand, but the occasional rock. So I'll anchor a bit farther out, then walk the boat into shallower water so we can walk back and forth to the boat and just climb up the swim platform. I still keep a foot or two under the props though, because I'd be concerned about waves or wake rocking the boat and "pounding" the gear into the sand. Don't know how much it would take to do damage, but don't want to risk that.
- LLL
- Vessel Info: 1988 Montego 3257
- Has thanked: 2 times
We installed bow steps on our 32 ft Montego. I plan on repairing the first set of holes my hubby drilled this year .
To be honest, I've seen people use telescope ladders without any issues. That may be a better option. That being said, I love our steps
At any rate, we beached and measures from where we wanted to mount steps to sand and went from there. You'll have to beach again too install.
88' Montego 3257
Users browsing this forum: g36 and 10 guests
