Gas Gauge
- Tort4247
- Vessel Info: 1995 355 carver
Gas Gauge
- Been thanked: 587 times
Re: Gas Gauge
- Has thanked: 432 times
- Been thanked: 1587 times
Re: Gas Gauge
If it's VDO chances are it's the European standard resistance. Hopefully it's a defective sender because its likely the gauges aren't available anymore unless you can find them on-line through someone like https://www.greatlakesskipper.com/
Don't forget you have access under the helm through the back of the forward bench if I remember correctly. From there, you can do a couple of other checks in addition to the one G36 mentioned. If that test doesn't tell you anything, don't be too quick to condemn the gauge or sender before checking your wiring, harness plugs, etc. If I recall, it's one gauge with a switch to check two tanks? If so, you want to confirm there's continuity through the switch too.
- Has thanked: 548 times
- Been thanked: 1145 times
Re: Gas Gauge
Tort4247 wrote:Source of the post I have a 1995 Carver 355 aft and my vdo gas gauge broke and I need to replace it but don't know what gauge to purchase with or without sending unit and ohms . The gauge had no numbers or model number on back . The plastic disintegrated
I have seen the resistance/ohm working range stamped on the sending unit....it was an older one though.
