Re: Some Information alluding me, PLEASE help!!
Has thanked: 58 times
Been thanked: 453 times
Re: Re: Some Information alluding me, PLEASE help!!
Postby waybomb » July 7th, 2024, 6:44 pm
Generator dip stick. Look outboard of the aircleaner,.a couple inches away from air cleaner.
Round vertical tube. The top unscrews. It has the dipstick attached to it. That is also the oil fill tube.
dgreene
Vessel Info: 1988 Mariner 3697
Twin Mercruiser 7.4L
Has thanked: 15 times
Been thanked: 9 times
Postby dgreene » July 9th, 2024, 5:29 pm
The one in under the v berth is difficult to get to. You have to crawl into the opening under the berth mattress and look into the small access opening. It should be just forward of the waste holding tank. It’s a major pain to get to it.
If you don’t have an AC in the v berth, then you may not have one there. Otherwise, maybe your forward AC uses is on the same pump as your salon AC.
Thanks,
Doug
1988 Mariner 3697
Key of Sea
Fairhope, AL
ohedron
Vessel Info: 1986 Carver 3697 Mariner
Postby ohedron » July 9th, 2024, 6:31 pm
In FRONT of the waste tank? I've beeb checking the port side and behind, closer to the AC, next time I'm at the boat I will make sure to look ALLL around!!!!! Thank you!!
ohedron
Postby ohedron » July 9th, 2024, 6:34 pm
Waybomb, OMG!! it unscrews?? The one thing I didn't think, I thought that was just the airvent, not BOTH vent and lipstick. THANK YOU!!!!
dgreene
Postby dgreene » July 10th, 2024, 8:13 am
ohedron wrote:Source of the post In FRONT of the waste tank? I've beeb checking the port side and behind, closer to the AC, next time I'm at the boat I will make sure to look ALLL around!!!!! Thank you!!
Yes, I’m pretty sure mine is slightly forward of the holding tank. The pics I have are just of the seacock and don’t show the location. I’ll try to get a better shot when I’m back on the boat.
Thanks,
Doug
1988 Mariner 3697
Key of Sea
Fairhope, AL
buster53
Vessel Info: 2001, Carver 356
Been thanked: 262 times
Postby buster53 » July 13th, 2024, 12:22 pm
Find anything yet?
