Fuel consumption differential
Crowbar
Vessel Info: 1987 Carver Voyager- twin 305 gas
Postby Crowbar » August 3rd, 2018, 2:45 pm
1987 28 ft Voyager. Twin 230 hp gas. 1580 hrs. My port engine burns between 1/2 and 3/4 gal./hr more than stb. engine. Is this excessive or sort of normal?
throwback2
Vessel Info: 1987 Carver 28 Voyager,twin small blocks
1973 Atlantic Craft 15, 2004 Merc 40
and a few other water toys
Has thanked: 3 times
Been thanked: 7 times
Re: Fuel consumption differential
Postby throwback2 » August 3rd, 2018, 4:41 pm
I have same boat and power.Both engines burn about the same. There's a lot of things that could cause this. Props could be a little different or slightly damaged,dirty flame arrestors,tune up needed,to name a few.
Been thanked: 203 times
Postby km1125 » August 4th, 2018, 11:29 am
Check your chokes and make sure they are completely opening when the engine is warm. I had the choke thermostat go bad on my stbd engine and it would stay 1/2 way closed when the engine was warm. Still ran good, but used noticeably more fuel.
Has thanked: 271 times
Been thanked: 421 times
Postby bud37 » August 4th, 2018, 3:01 pm
Could I ask, how are you measuring this fuel use ?
Crowbar
Postby Crowbar » August 8th, 2018, 11:47 am
Thanks for the tips. I'm measuring when I fill the tanks. Typically, the stb will take 30 gal and the port will take 38-40gal
amanphoto
Been thanked: 11 times
Postby amanphoto » August 8th, 2018, 12:50 pm
Check your propeller shaft drag. Do both propeller shafts have the same resistance when you manually turn them by hand (transmissions in neutral)?
1990 Proline 17CC
2018 Regal 1900ESX
Has thanked: 94 times
Been thanked: 248 times
Postby tomschauer » August 21st, 2018, 7:28 pm
if they are both tuned well, and your running gear is in good shape, it could be as simple as a sync problem. You would be surprised wahy a couple hundred RPM's will do.
If you don't have a sync, try pushing the starboard up a couple hundred rpm as read on the tach and see if it balances out.
Users browsing this forum: No registered users and 1 guest
