Carver C34
dirtdoc1
Topic author - Scurvy Dog
- Vessel Info: 2013 Carver C34
Carver C34
Anyways, I hope to hear from some other C line owners.
Cheers!
Dirtdoc1
- Been thanked: 490 times
Re: Carver C34
I really do not like the idea of no radar arch - where are you supposed to mount a radar array, and support tall antennas? Sure you can mount a closed dome in front of you and blank the microwave transmission at yourself, but I like to see what's coming up from the rear, especially in a foggy area.
What were they thinking????????
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Carver C34
SeaDragon
dirtdoc1
Re: Carver C34
dirtdoc1
Re: Carver C34
waybomb wrote:Be glad the engine is a closed system. Salt water and gas engines aren't good for each other.
How did you know that it has a closed cooling system? I had to ask the salesman and he had to check with Carver.
dc
Re: Carver C34
The raw water will remove the heat from the antifreeze just like air does in a car. The salt water never gets into the engine cooling system at all.
dirtdoc1
Re: Carver C34
waybomb wrote:There will be a heat exchanger mounted somewhere above/on the engine. There will be a radiator cap and a reservoir with antifreeze in it.
Thanks Waybomb, I'll look for that. I still haven't taken possession of the boat yet. It's currently over in Oakland getting the radar arch and electronics installed. It is far easier to buy a house!
Cheers!
Re: Carver C34
melvus
- Vessel Info: Carver C34;2014
- Has thanked: 1 time
Re: Carver C34
Users browsing this forum: No registered users and 223 guests
