Carver 466 - charging house batteries via generator?
Topic author - Scurvy Dog
- Vessel Info: 2003 Carver 466
Thanks for any feedback.
Doug
- Ramsport47
- Has thanked: 72 times
- Been thanked: 56 times
Re: Carver 466 - charging house batteries via generator?
T-Merc 350 Mag MPI (300hp)
- Been thanked: 587 times
http://www.victronenergy.com/battery-monitors/BMV-700
- Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada - Location: Lake Simcoe Marina
- Has thanked: 6 times
- Been thanked: 17 times
It's likely that your generator run time was simply insufficient to bring your house batteries back up to 100%. You are probably replacing only a partial amount of the amp-hours you need. When you go back on shore power, you're on overnight or longer, giving your batteries the full charge. The problem, as another writer mentioned, is that we are just guessing when we run the genny.
We need a 'fuel gauge' for the batteries. Wouldn't that be nice? There is such an instrument. Available at West Marine.
I was guessing for years, until I saw one of these on a friend's boat, and later installed one myself. It tells you the exact percentage of battery power left, or in volts if you prefer that information. It's also a gas saver, because you know when the battery is full and you don't need to run the genny any longer.
http://www.xantrex.com/power-products/p ... nitor.aspx
MerCruiser MX 6.2
Lake Simcoe, Ontario
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 26 times
- Hugo
- Has thanked: 2 times
- Been thanked: 20 times
http://www.eastpennmanufacturing.com/wp ... t-0194.pdf
A typical new 8D battery will give you about 245 amp hours before dead but that's really 122 since you don't want to discharge them below 50% capacity. If you have two wired in parallel you have roughly 490 amp hours of which 245 is usable with 50% left. That should run your fridge (let's say 8 amps) for about 30 hours before you go below 50% capacity. That's probably at least two days as the fridge won't draw current nonstop. keep in mind that as batteries age they loose capacity so you may be well below this amp hour rating depending on the batteries age.
What is the voltage of your batteries after you shut engines down on the hook and after 6 hours?
A simple ammeter will tell you what the current draw is on the batteries if you don't have a battery monitor.
If you're fridge is the only draw on the batteries and is 8 amps, that's 48 amps after 6 hours give or take if it ran constantly. You get the idea...
I also have a Victron BMV monitor and it's pretty good and accurate at telling you how much current in being drawn from batteries, voltage, etc. It's sort of a must if you're going to spend a lot of time on the hook.
- Lyndon670
- Has thanked: 124 times
- Been thanked: 139 times
Two points of interest. When I bought my 506 in February of 2014 with a tick under 200 hrs on my Volvos, we had a similar charging/recharging issue. After some basic diagnosis, it turns out that both alternators were suspect - they were charging but not putting out enough to do the massive battery bank. I also replaced all of the batteries on the boat too. In for a penny, in for a pound. My point or rather my question is - how old and what condition are your batteries? We have a rough service life up here in the northern climates and it's rough on batteries sitting dormant even if fully charged. My rule of thumb on my batteries in all my boats has been 4 years and I become suspect.
Also, your inverter supplies power to your TV, entertainment centers, and icemaker AND bridge fridge if you have one.
Second, the inverter system that we both share has the digital display that shows all of the information that the gauge that After Taxes suggested. Just cycle through the menu and you will see all of the data.
And, as Hugo suggested - battery management is the key. When I anchor out, which I do a lot, I only run off the batteries from when I go to bed until I wake up. And then I fire my genny. The worst thing for a genny is not to use it. They don't like being shelved. I never go more than an overnight (say 12hrs MAX) with out firing my genny.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Thank you very much for the comments. I replaced all 4 8D batteries last fall (2 for house and 2 for engine starting) so they are basically new. I suspect the inverter/charger is not enough to charge them when running the generator since I have left it running for 24 hours with minimal charge to the batteries. I will look into one of the battery monitors to see what is going on.
Thank you very much as your comments confirmed my suspicions.
