12" Fluorescent Lights
Posted: April 12th, 2018, 3:46 pm
by williamloden
I have four(4) of these in my 430. Two(2) in the galley and one(1) over, behind each bed.
Are these lights 120VAC or 12VDC? Thank you.
Re: 12" Fluorescent Lights
Posted: April 12th, 2018, 4:08 pm
by g36
Most likely 12vdc I had these in my 405. 2 in galley 2 behind dinette and 1 forward head. Replaced with led string on the ones that were more hidden and put a led string inside the fixture that was easily seen and thought it looked good s o I left it up. The leds gi've way more light and helps in the galley alot
Posted: April 12th, 2018, 4:23 pm
by mjk1040
Not to mention draw less juice and produce a lot less heat.
Posted: April 12th, 2018, 5:03 pm
by Midnightsun
I agree, chuck the fluorescent and go with LED. Outdated and will be impossible to buy in a few years. LED is definitely the new lighting system and here to stay for quite some time.
Posted: April 12th, 2018, 7:44 pm
by williamloden
Thanks for the answers. Saw a YouTube on replacing fluorescent with led string in an RV. That's the way I'm gonna go!
Posted: April 13th, 2018, 1:17 pm
by buster53
Agree with LED's, but to answer your question, I'm 99% sure your florescents are all 12V. I've never seen a 120v florescent fixture on a boat.
Posted: April 14th, 2018, 12:43 am
by RGrew176
buster53 wrote:Source of the post Agree with LED's, but to answer your question, I'm 99% sure your florescents are all 12V. I've never seen a 120v florescent fixture on a boat.
Same here. I have one on my 3007 over the galley stove and it's 12V.
Posted: April 14th, 2018, 10:35 pm
by tomschauer
The t-5 fluorescent's use a 12 vdc ballast on your boat. The tubes, however are standard t-5's lamps and you can buy them at lowes or home depot. They are not as energy efficient as LEDS, but they are the next best thing. The t-5 lamps should be available for many years before they are discontinued.
Posted: April 21st, 2018, 3:05 am
by PhilH
HI. Not to push a brand but found these on Amazon: " LED Under Cabinet Lighting Touch Control, Dimmable Under Counter Light Strips for Kitchen Closet, Shelf, 3 pcs Light Bars Kit, 12W 1200 Lumen, 4000K N"
Sold by: youthink us
$29.99
Have bought 6 sets in past year and every set has been perfect. Small, 3- 12" lights/box, runs on 12 V DC or 120 AC with wall wart, uses very little power, bright, fits under cabinets. Planning to put them under every area I need light.!
