blower for diesel generator
- winedown
- Vessel Info: 2004 396 Carver motor yacht
- Has thanked: 17 times
- Been thanked: 3 times
- Been thanked: 587 times
Re: blower for diesel generator
- winedown
- Has thanked: 432 times
- Been thanked: 1588 times
- winedown
You may want to follow the wiring from the blowers and see if there are any plugs along the way that may have been disconnected. The next thing to check would be if there's 12 volts actually getting to the blowers. This can easily be done if you're familiar with using a volt meter. Turn the blowers on at the switch, then take your measurements. If there's power there, then the blower/s likely need replacing. If there's no power at the blower/s, then you need to trace back to the source until voltage is observed.
