Mariner Forward Bilge Water
- denpooch
- Has thanked: 85 times
- Been thanked: 86 times
I believe that this is likely caused by a siphoning of water into the bilge via the forward bilge discharge thru hull fitting.
One gentleman in a post suggested that the water intrusion completely stopped when he duct taped over the thru hull.
Has anyone come up for a solution to this problem without using duct tape? I hate having standing water the the bilge and dread having to wet vac 5 or 10 gallons of water out of there after most cruises. Thanks
- Bandit
- Vessel Info: ‘99 Carver 404
- Been thanked: 4 times
Re: Mariner Forward Bilge Water
Not sure of your design however In my 404 I was chasing a leak in the forward compartment and the mid section was dry leading me to believe it was coming from somewhere in the front. I later discovered it was a loose exhaust hose clamp in the stern and water was running forward inside the stringers leaving the mid section dry and had me looking in the wrong place.
- Has thanked: 550 times
- Been thanked: 1150 times
denpooch wrote:Source of the post Like many Mariner owners, my boat has a tendency to 'collect' water in the forward bilge, especially after a cruise in larger seas.
You could put a clamshell like fitting over the bilge pump outlet, much like the one over the generator outlet.....perhaps that might help until you can find the attachment point inside and make sure there is a loop there.Sometimes I think because these boats have liners, water can sit behind from rain etc and then when the boat gets bounced around it finds its way out and into the bilge, ours has these odd occurrences as well.
- denpooch
Perhaps the check valve is more realistic.
Bud, my only concern about installing a clamshell (with the opening facing aft) is the 'interference' created by the shell when the bilge turns on to evacuate. I don't know if that shell would compromise the pump function.
Thanks guys.
- mjk1040
- Been thanked: 236 times
- denpooch
Users browsing this forum: No registered users and 46 guests
