dual station switch issues
- Has thanked: 548 times
- Been thanked: 1145 times
Re: dual station switch issues
If you can check volts across the button, then try to jump across the button terminals and see if the switch works as normal....like your car...that should give you an idea. If you aren't comfortable get a marina tech to check that for you......good luck with it.
- Johnnymalibu
- Vessel Info: 1984 Carver Santa Cruz
km1125 wrote:Source of the postMidnightsun wrote:Source of the postJohnnymalibu wrote:Source of the post
yes you push it in to start then release it .
yes we have a key
Need more info. Do you turn the key to on then push the button until it starts and then release the button once started? To turn off do you simply turn off the key?
And what happens at the lower station... does it have a key also?
yes it has a key , it will not work unless someone goes up on the fly bridge and holds the button in
- Has thanked: 58 times
- Been thanked: 969 times
It is diesel or gas?
- Johnnymalibu
km1125 wrote:Source of the post Is this a single engine or dual engine? If a dual, is there a separate push button for each engine?
single engine , gas
- Johnnymalibu
bud37 wrote:Source of the post Welcome to the forum......just a guess here, but I think the button is providing the start function and the key is the run power.....maybe a type of anti theft device or just filling in for the solenoid/relay. Those two things are generally provided by the key switch itself, off, run, start.
Thank you
- Johnnymalibu
I would say it's a bad key switch, but that means you would have TWO bad ones (one up and one down). The fact that there's a button next to one that you can push means that all the "signals" are available at the key switch to work correctly, as that button should have the same function as the temporary "start" position on the key switch. Also rules out a bad solenoid or start relay somewhere else.
Users browsing this forum: Google Adsense [Bot] and 44 guests
